Results 1 to 3 of 3
  1. #1
    Default 4.3 cobra no neutral
    So I have a 20' cuddy with a 4.3. The boat shifts into neutral fine when off, prop spins free with no noise. In the water, I can't get into neutral. It's either in forward idle or reverse idle. I can have the shifter dead in neutral and it won't find neutral. I had to do some work to it Last week I put it in a tank and was running it. Could shift into F and R, and in neutral worked fine. Could spin the prop with a stick while engine running. Back into water yesterday and same thing. I can't get neutral in the water. Any ideas? Thanks in advance!
  2. #2
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,469
    Default Re: 4.3 cobra no neutral
    Ayuh,.... Sounds like the shift interrupt switch ain't workin',....
    Unfortunately,... I donno how OMC wires it,...
  3. #3
    Quote Originally Posted by bondo View Post
    so if the shift interrupt isn't working, will the engine speed be too high to have it slip into neutral?
Similar Threads
  1. 1989 OMC 5.7 cobra neutral idle rpm?
    By Falcon195 in forum OMC Sterndrive and Inboard Forum
    Last Post: 05-15-2011, 08:17 PM
  2. 50 Cobra noise in neutral
    By LD in forum OMC Sterndrive and Inboard Archive
    Last Post: 08-06-2006, 11:51 PM
  3. Omc cobra lower unit nightmarevolvo sx or king cobra swap
    By 91mariah50omc in forum OMC Sterndrive and Inboard Archive
    Last Post: 06-30-2006, 03:00 AM
  4. King Cobra wonbt shift into neutral while engine is running
    By marcell in forum Archive 2003-2009
    Last Post: 05-22-2003, 12:19 AM
  5. Replies: 0
    Last Post: 12-31-1969, 07:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
