Results 1 to 3 of 3
  1. #1
    Default How to adjust VRO Oil flow rate?
    My 1989 Evinrude seems to be going through a lot more oil than advertised: should be a small amount per 6 gal tank. We are going through more. Engine smokes. Is there a way to adjust the flow rate of the oil?
  2. #2
    Join Date
    May 2011
    Location
    slough ,berkshire uk
    Posts
    161
    Default Re: How to adjust VRO Oil flow rate?
    there is no adjustment on the vro, it either works good or goes bad.
    it cost a fortune for a new one, and nobody repairs them, they are total crap.
    get a new but old style fuel pump, you wont regret it. you always know the motor is being lubricated correctly if e pre-mix is in the tank.
    I would never ever trust vro on any engine, it realy is a killer.
    the old style pump was around forever and was ultra reliable.....
  3. #3
Similar Threads
  1. Mercruiser overheating- How to check raw water pump flow rate
    By gpolkin in forum Mercruiser Sterndrive Forum
    Last Post: 10-07-2012, 09:33 AM
  2. Water flow rate for OMC outdrive impeller for 57 liter
    By captcal in forum OMC Sterndrive and Inboard Archive
    Last Post: 05-09-2008, 07:49 PM
  3. Charge rate
    By stewart9224 in forum Yamaha Outboard Archive
    Last Post: 05-08-2008, 02:18 AM
  4. Labor rate
    By atilla_boy in forum Mercruiser Sterndrive Archive
    Last Post: 12-16-2007, 08:09 PM
  5. Labor rate
    By dervin in forum Outboard motors archive 2000-2004
    Last Post: 02-23-2003, 01:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
