Results 1 to 12 of 12
  1. #1
    Default 1990 70 HP Evinrude VRO Problem
    Experiencing an alarm at slow (trolling) speed which my be a 'low' or 'no' oil alarm. Comes and goes in random intervals. I would say half a second on and half a second off. Engine running great and no alarm at fast speeds. Plenty of oil in the reservoir. Engine passing lots of water which isn't hot. I replaced this unit many years ago when it was diagnosed as a faulty alarm. Is this a common problem with other OMC alarms?
  2. #2
    Join Date
    May 2011
    Location
    slough ,berkshire uk
    Posts
    162
    Default Re: 1990 70 HP Evinrude VRO Problem
    have you thought about cleaning the filter in the oil tank ? and what about the tiny little skinny oil filter under the hood ?
    have you cleaned oil out of oil tank and filtered it to make sure it is not gelling at the bottom of the oil tank ?
    what about checking the oil line itself for a blockage ?
  3. #3
    Hi, I haven't but it is a good place to start. It just seems strange to me that it only occurs at low speeds.
  4. #4
    Join Date
    May 2015
    Posts
    2,111
    That is the no flow alarm start mixing your gas and oil I mix Amsoil 100-1 until I find the problem. Start looking at all the clamps especially if you used the OMC plastic clamps. If you clean the filter in the tank you have to Bleed the whole system. Those alarms can go bad not common but it can happen. You can also have a bad tank sensor which is more common especially if it is the original.
  5. #5
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    15,785
    That fast every other second beep indicates that oil is not being supplied to the VRO properly. When that alarm sounds, apply some pressure to the primer bulb at the oil tank to force possible air in the line to move along. I The line may simply need re-priming as follows.
    (Priming The VRO Pump)
    (J. Reeves)
    When hooking up or installing a VRO whether it is a new or original VRO pump, it must be primed in order to dispel any air that might be in the oil line.
    Have the Oil line attached to the engine fitting BUT detached from the VRO. Add a piece of fuel hose if necessary to the oil line so that it can be aimed into some sort of container.
    Pump the oil primer bulb, catching the oil flowing out of the line into the container until you are absolutely sure that you have rid the oil line of every bit of air that might have been trapped there.
    Now, connect the oil line to the VRO and secure it. When the oil line is secured, apply pressure to the oil primer bulb ONE TIME only. That's it.
    (VRO Horn Warnings)
    (J. Reeves)
    NOTE: I retired around 1991/92. Possibly some of the later V4 engines and others may also incorporate a fuel vacuum switch that would enable a fuel restriction warning to sound as mentioned below, an unknown factor to myself.
    1 - A steady constant beep = Overheating - The V/6 engines, possibly some others, have a fuel restriction warning which is also a steady constant beep.
    2 - A beep every 20 or 40 seconds = oil level has dropped to 1/4 tank. (Late model engine = Every 40 seconds)
    3 - A beep every other second = VRO failure, air leak in oil line, oil restriction, (anything that would result in a lack of oil being supplied to the engine).
    NOTE - If the warning horn is the black plastic (overpriced) three wire type horn, the warning horn should beep once when the ignition key is turned to the ON position. If it does not, it is either faulty or someone has disconnected it (a stupid move!). At any rate, if it does not beep which indicates that the horn is non functional, find out why and do not run the engine until the problem is corrected.
    We occasionally have questions. If you fail to answer, it may affect ours.
  6. #6
    Thanks for the help guys, time to start tinkering!
  7. #7
    Join Date
    Feb 2001
    Location
    Posts
    15,785
    Quote Originally Posted by StevieP View Post
    Tinkering is for people who don't know what they're doing! Stop that!
  8. #8
    Thanks! That would be correct in this case as I'm a biologist not mechanic. Are you suggesting to go to a mechanic? It just puzzles me why it only happens at low speeds.
  9. #9
    Join Date
    May 2015
    Posts
    2,111
    I would check the pulse line that is behind the pump and make sure you have the blue pulse limiter. I would also bleed the whole system and buy a factory manual for the motor.
  10. #10
    I'm not sure whether or not you've managed to find a solution to your "alarm" problems at slow speed, (since I just got on this site and your post is a couple of years old now, but here's a link to a great article dealing with your problem as well as some good PM instructions for VRO motors;
    http://continuouswave.com/whaler/reference/VRO.html
  11. #11
    Hi,
    I ended up removing the VRO system so now pre-mix fuel and oil.
  12. #12
    Join Date
    Feb 2001
    Location
    Posts
    15,785
    There'ya go!
Similar Threads
  1. 1990 20hp evinrude problem
    By catangler in forum Johnson Evinrude Outboard Forum
    Last Post: 09-06-2010, 11:22 PM
  2. 1990 Evinrude 120 problem
    By hosellw in forum Johnson Evinrude Outboard Forum
    Last Post: 03-20-2010, 12:46 PM
  3. Evinrude 1990 115 hp vro problem
    By kuri in forum Johnson Evinrude Outboard Archive
    Last Post: 04-05-2009, 08:14 PM
  4. I have a problem with a 1990 evinrude v6 150
    By michael macy in forum Johnson Evinrude Outboard Archive
    Last Post: 08-01-2006, 04:43 PM
  5. 1990 100hp Evinrude idle problem
    By scott in forum Johnson Evinrude Outboard Archive
    Last Post: 04-25-2004, 02:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
