Brendanpd2
Hey all,
New to the forum. I have a 1976 Aquasport 170 with a 1990 Evinrude 88 SPL Outboard. I recently had awful phase separation issues in my below deck 27 gallon aluminum fuel tank. I believe it was a bad fill up from a local fuel dock. My tank, lines, filters, etc... are all brand new. I used my existing fuel line and primer bulb to manually drain the bottom of my tank. I endded up draining about 10 gallons until there was no more evidense of water or phase separation. The 3 pictures attached are when it was first discovered, after draining a few gallons, and after draining 10 gallons. My question is....does anyone know how to drain the carb bowls on this motor? Do i need to remove the carbs completely? The lowest screws I can find on the carbs are the plugs for the high speed jets. I am changing my fuel pump for good measure as well. Thanks!!
