Click for Chrysler parts and manuals!
Results 1 to 6 of 6
  1. #1
    Default 1977 Chrysler 360 engines both won't go over 2800 rpm
    Ran fine last year. Went for ride and cannot get both engines over 2800 rpm at full throttle. Help any suggestions would be appreciated.
  2. #2
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,477
    Default Re: 1977 Chrysler 360 engines both won't go over 2800 rpm
    Ayuh,.... Odds are is goin' lean from bad fuel, or bad fuel flow,....
    Check the contents of the fuel filters for anything but clean fresh gasoline,....
  3. #3
    Join Date
    Mar 2015
    Location
    Toledo Ohio
    Posts
    11
    Check to make sure the FLY-WEIGHTS in the distributer free to advance the spark properly.........Ray
  4. #4
    Quote Originally Posted by Rehi99 View Post
    I have the same problem with 1 of my 360s. Been chasing the problem for a few years. Still haven't found it. Done heads, cam, lifters, valve springs, carb., new dist., fuel filters, checked exhaust for blockage, and still have not found the answer. I'm out of ideas. Other motor runs perfect. I still need help.
  5. #5
    Join Date
    Nov 2005
    Location
    Chi West, IL, USA
    Posts
    784
    Linkage or cable bind possible? Do throttle plates in carbs open completely?
    Have you tried disconnecting the tach/tachs?
    Checked fuel pump pressure? Fuel pump volume?
  6. #6
    Is the hull free of marine growth?
Similar Threads
  1. Free PDFs Chrysler Engines
    By georgeinbeverly in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 05-24-2009, 10:39 PM
  2. How are small Chrysler 4 HP engines cooled
    By roopzz in forum Chrysler Force Outboard Forum
    Last Post: 03-23-2009, 09:34 PM
  3. Chrysler Engines 235HP
    By lasandi1 in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 02-16-2009, 04:20 PM
  4. 426 chrysler marine engines
    By nutsnboats in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 11-05-2008, 11:47 AM
  5. Chrysler Marine Inboard Engines
    By stuart in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 09-13-2006, 09:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
