Results 1 to 10 of 10
Thread: Eska
  1. #1
    Default Eska
    Does anyone no where to get Eska 1974 5hp service manual
  2. #2
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,735
    Default Re: Eska
    Try discount marine parts.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  3. #3
    Default Re: Eska
    Quote Originally Posted by kimcrwbr1 View Post
    Thank you I will
  4. #4
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,735
    Default Re: Eska
    That is a tecumseh built air cooled engine you can go to sears parts direct model number 21759680 and look up part numbers. Yuo can probably get any engine parts at you local small engine repair shop. It is basically a two stroke lawn mower engine mounted on a outboard. The water pump is to keep the exhaust cool.
  5. #5
    Default Re: Eska
    Do you think the impeller is necessary or will it be fine without one
  6. #6
    Default Re: Eska
    Sounds like you have worked with these motors
  7. #7
    Default Re: Eska
    Woul you no of any Tecumseh carboratour that would work as a replacement for this motor
  8. #8
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,735
    Default Re: Eska
    No and no. Do not run it without water to the exhaust unless you dont mind getting a first degree burn by touching the leg. You will need to find a suitable replacement with the right venturi and nozzle size.
  9. #9
    Default Re: Eska
    I have my carboratour off of engine if there is fuel in the bowl and I flip it over fuel comes out a little hole in the centre of the carb should that hole be plugged off or is it supposed to be open HELP. Rick Lumley
  10. #10
    Default Re: Eska
    Does the 1974 Eska 5hp have water jackets in the block
Similar Threads
  1. need help with an eska
    By dms-13 in forum Eska Outboards
    Last Post: 04-26-2013, 05:23 PM
  2. Help with my Eska
    By wasteguys2000 in forum Eska Outboards
    Last Post: 05-16-2012, 08:08 PM
  3. Eska Files - Links to Eska resources online
    By MrCrabs in forum Eska Outboards
    Last Post: 06-15-2011, 09:51 AM
  4. Eska 51
    By whynot in forum Johnson Evinrude Outboard Archive
    Last Post: 06-13-2009, 07:37 PM
  5. What Eska do I have
    By tamram in forum Archive 2003-2009
    Last Post: 05-06-2006, 10:16 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
