Results 1 to 2 of 2
  1. #1
    Default Volvo Penta 5.0GL Power improves when under electrical load
    I have a 2002 Regal with a 5.0 Volvo GL PEFS, I recently replaced, coil, plugs, wires, dist cap and rotor. Boat at times runs well, then all of a sudden it boggs down, when i put a load on the electrical system like hit the trim tabs, lights etc.... the engine smooths out.
  2. #2
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,439
    Default Re: Volvo Penta 5.0GL Power improves when under electrical load
    Ayuh,.... Sounds like corroded grounds,....
    Start at the battery, 'n Clean All the cable connections to shiny clean metal,....
    Both cables, 'n Both ends of the cables,....
Similar Threads
  1. Volvo Penta 5.7 loses power under load
    By tortguy in forum Volvo Penta Gas Engine Forum
    Last Post: 02-03-2017, 10:03 PM
  2. Volvo Penta 4.3GL Electrical Problems
    By Yankiwi in forum Volvo Penta Gas Engine Forum
    Last Post: 05-07-2015, 10:40 PM
  3. Volvo Penta AQ 231 - Electrical Problem - Help!!!
    By Alce Deal in forum Volvo Penta Gas Engine Forum
    Last Post: 10-21-2013, 09:32 AM
  4. Volvo Penta Aq 231 A Electrical Problem
    By TimH615 in forum Volvo Penta Gas Engine Forum
    Last Post: 06-05-2011, 11:22 PM
  5. Volvo Penta 57Gxsi DP 2006 Electrical
    By b4240 in forum Volvo Penta Gas Engine Forum
    Last Post: 09-08-2009, 01:24 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
