Results 1 to 2 of 2
  1. #1
    Default 87 3.0 eng water in block from flooded boat fix?
    Best way to get all the water out of block?
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,184
    Default Re: 87 3.0 eng water in block from flooded boat fix?
    Assuming it sank, you may wanna consider the fuel tank, too. You may have electrical issues as well...beyond that....
    You'll wanna get the water out ASAP....drain the oil, change the filter, pull the plugs and put new oil in....spin it over. plugs in, good fuel to the pump and then run it....you want to get it up to operating temp....under load if possible....if it runs well and you are happy it wasn't hurt, then change the oil and filter again....
Similar Threads
  1. 87 3.0 eng water in block from flooded boat fix?
    By Cobra man in forum OMC Sterndrive and Inboard Forum
    Last Post: 06-28-2017, 10:39 AM
  2. Just got a used boat, possible cracked block, advice? Thanks!
    By COchoa in forum OMC Sterndrive and Inboard Forum
    Last Post: 10-25-2012, 06:15 AM
  3. M360 Flooded with Water - What next?
    By Resorter_Dude in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 10-22-2010, 04:51 PM
  4. Engine flooded with water 1978 140a
    By dusher in forum Volvo Penta Gas Engine Forum
    Last Post: 03-09-2010, 08:39 PM
  5. Boat flooded wondering what all to check
    By Dean Jordan in forum Volvo Penta Gas Archive
    Last Post: 10-13-2006, 09:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
