Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 6 of 6
  1. #1
    Default Dead cylinder on 50 hP Chrysler
    Have an 84 Chrysler 50 HP. Top cylinder won't fire Getting spark and fuel. Compression about 110 PSI, 120 on lower cylider. Any help would be greatly appreciated. Not well versed on 2 cycle engines.
    Thank you
    arizona Lou
  2. #2
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,409
    Default Re: Dead cylinder on 50 hP Chrysler
    Possibly the reeds?
    Pull the carb and see if they are ok?
    Swap the coils around and see if that helps?
    Swap plugs?
    88 Bayliner with 2002 225 HP Mercury EFI
    Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
    ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
    In Scenic , Beautiful San Sebastian by the sea Florida
  3. #3
    Thanks Jerry,
    I did swap plugs, makes no difference. Engine dies when I remove the lower plug. Do you think the reeds would affect just one cylinder? Just asking. Been a mechanic all my life but not on 2 cycles.
    Thanks again
  4. #4
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,409
    Yes the reeds can affect just one.
    Each cyl. has it's own intake reeds.
  5. #5
    I ordered new reeds. Will update you when I pull it apart.
    Thank you,
  6. #6
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,409
    Don't order until you take them apart.
    It could be something different.
    Without seeing the motor?? that would be my best GUESS!!
Similar Threads
  1. dead cylinder
    By baffled2 in forum Mercury Mariner Outboard Forum
    Last Post: 05-31-2015, 12:14 AM
  2. Dead Cylinder
    By John Carver in forum Mercruiser Sterndrive Forum
    Last Post: 05-20-2012, 11:21 AM
  3. dead cylinder
    By bobbykey in forum Nissan Tohatsu Outboard Forum
    Last Post: 05-03-2012, 08:24 PM
  4. #2 Cylinder Dead
    By tboltmike in forum Johnson Evinrude Outboard Forum
    Last Post: 07-24-2011, 10:20 PM
  5. dead cylinder
    By 38harry in forum Mercury Mariner Outboard Forum
    Last Post: 06-01-2011, 09:21 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
