Click for Chrysler parts and manuals!
Results 1 to 5 of 5
  1. #1
    Default Will a 318 motor from a car work in a boat.
    I have a 28 foot Land and sea. Can a 318 Motor from my car replace the one in the boat. And I would like to design a radiator system to install in the boat. It's only in freshwater not the ocean.
  2. #2
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,469
    Default Re: Will a 318 motor from a car work in a boat.
    Ayuh,.... What motor is in the boat now,..??
    What year is yer car's 318,..??
    A radiator is a dumb idea when the boat is surrounded by freshwater,....
    Can't get enough air flow for a radiator anyways,...
  3. #3
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,730
    Your best bet is to rebuild the engine you have if still serviceable. You may be able to swap parts to a car engine cam, distributor, heads but do not attempt to make it radiator cooled it will never work. Think of your car pulling a trailer full of rocks up a mountain pass whenever in forward gear. Our boat engines work hard you have go and stop and being a displacement hull that makes that little 318 work even harder you would be lucky to ever hit a good plane.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  4. #4
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,799
    Quote Originally Posted by Land and sea View Post
    First off...... this would be an Engine, not a motor! (no offense..... my pet peeve!)
    However, the short answer is yes...... it will work in a 28 foot boat for a rather short time only!
    The automotive cylinder head gaskets will work for a short duration before raw water cooling causes corrosion that will eventually take it's tole on them.
    Depending on the Automotive application, the Static Compression Ratio may be incorrect for Marine use...... especially in a 28 footer!
    The Automotive ignition advance will be excessive and may cause issues...... and again, especially in a 28 footer!
    The camshaft profile may offer excessive over-lap that could cause water reversion, eventually damaging exhaust valves.
    As for engine cooling, the equivilant of an automotive radiator will be a Marine Heat Exchanger.
    These use liquid as the much more efficient media for heat removal.
    If a heat exchanger is used, the automotive cylinder head gaskets will work!
    In the long run, you will do much better if you were to go with a specifically built Marine Engine..... better yet, the Chrysler 360 cu in engine.
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
  5. #5
    Join Date
    Jun 2008
    Location
    Island Heights, NJ,
    Posts
    2,788
    Ditto the 360 engine....
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
    1972 22ft Bristol
    Honda 7.5HP 4 stroke Long shaft
Similar Threads
  1. Prop for tow/work boat (20 ft' flat bottom/90
    By DealLakeBoater in forum Propeller Selection and Replacement
    Last Post: 06-06-2013, 09:27 AM
  2. Pontoon boat, anode. how do they work
    By meandmyharley in forum Boat Maintenance
    Last Post: 10-20-2012, 04:35 PM
  3. Boat wont work??
    By kghost in forum Mercruiser Sterndrive Forum
    Last Post: 08-14-2010, 03:38 PM
  4. Starting to work on the boat
    By knehdn in forum Mercruiser Sterndrive Archive
    Last Post: 07-03-2008, 01:08 AM
  5. 90HP Ocean Pro on Pontoon boat Tilt will not work
    By scumbuster in forum Johnson Evinrude Outboard Archive
    Last Post: 04-11-2007, 02:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
