While cruising I have noticed that every 5 minutes or so I lose power to the prop. The immediate effect is a sudden slowing of the boat accompanied by a change in noise to a higher pitched whirring.
The boat is new to me but the previous owner had looked into it and tells me it's a problem with the clutch. He said he thought it was loose.
I have a 7m cabin boat with a Volvo Penta B20. The engine is mounted in the middle of the boat, drive train about 2m, running under the boards to the prop.
Has anyone experienced a similar fault? Is the clutch the likely cause?
