Results 1 to 9 of 9
    Default 1966 60hp stalls in low idle
    Hi, my 60hp (vx-12, 1966) stalls in low idle (runs fine otherwise). I tried adjusting low speed needles but to no avail (unless I'm doing it wrong).
    I removed the needles for inspection and there's hardly any wear on them although the washers are pretty messed up. Will new washers alone fix the problem? What other type of troubleshooting should I consider?
    Daniel
    Apr 2010
    4,255
    Default Re: 1966 60hp stalls in low idle
    Do a compression test on it.
    Just did compression test. Not good: 90, 35, 30, 30.
    But, I changed rubber washers on slow speed needles and it started right away purring like a kitten, at low idle. I was amazed!
    Rode at slow speed for about 5 minutes and just as I was to increase throttle, it died. Tried restarting it but no go. Thought battery had died. Went to hand crank it and the motor seems seized!! Rode back home with the electric motor : (
    Yep, the motor's seized now, can't budge the flywheel.
    grr..
    Sep 2010
    ontario
    15,251
    In nuetral ?----Checked recoil interlock ?---Did you install a new impeller?--------Mixing gas and oil at 50:1 ratio ?-----Checked lower unit gear oil ?
    Yep, in neutral. Thanks for tip on the recoil interlock, will do that in the morning. Gas and oil ratio is good.
    Why would I replace impeller? Will check that too.
    Thanks.
  6. #6
    Sep 2010
    ontario
    15,251
    Many folks will replace the impeller after the motor has come to a " dynamic halt " I guess.-----------Cooling water is most important !!
  7. #7
    Nov 2011
    1,929
    It shouldn't even be running at only 30psi on 3 cylinders. You need to figure out what is causing that before wasting time on anything else. Could be a candidate for the bone pile.
  8. #8
    Check the fuel pump, it may need to be rebuilt. It may be starving for gas.
  9. #9
    Apr 2010
    4,255
    Run another compression test with a different gauge.
  1. 1966 Evinrude 60hp -Running rough
    By Mikka8701 in forum Johnson Evinrude Outboard Forum
    Last Post: 11-04-2014, 01:34 AM
  2. Evinrude 60hp 1966 60652
    Last Post: 04-12-2014, 10:28 AM
  3. 1966 evinrude 60hp wont run
    By fisherking in forum Johnson Evinrude Outboard Forum
    Last Post: 07-22-2010, 06:20 PM
  4. 1966 60hp evinrude flooding
    Last Post: 06-24-2010, 08:07 PM
  5. 1966 60hp with no spark
    By butch in forum Johnson Evinrude Outboard Archive
    Last Post: 02-13-2006, 03:22 PM
