Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 3 of 3
  1. #1
    Default Nissan NSD50B Power Trim & Tilt
    I have a 2004 Nissan NSD50B, (new Tilt and trim style)the power trim quit lifting, the motor and pump works, I first tried adding fluid as I was bleeding it starting leaking from under the resiviour cover. I ordered the O-Ring, Installed today, as I was filling and bleeding with the ramp disconnected from the motor it seemed to be fine, then all of a sudden it started leaking again. I took the unit off and lloked at the part diagram theres not much on the piston side it did come with a couple more O-Rings, but I can't figure how to get the piston out. After you take off the res cover there is a round alluminum something with holes that the fluid goes through and the outside is round, the inside is like the outside of a 6 point axle socket, the rod goes through the center of this. I s it possible to ad to much fluid where it will cause it to leak, again a brand new O-ring and the cover and base look good no nicks. Any help is appreciated. Thank You
  2. #2
    Join Date
    Mar 2010
    Location
    Buffalo, NY, USA
    Posts
    2,212
    Default Re: Nissan NSD50B Power Trim & Tilt
    No, you can't over fill. Here is the exploded diagram to show you how it all goes together. If you have a leak at the base of the ram cover, odds are the o-ring is not seated properly, or might be the incorrect size.
    Paul
    Buffalo NY USA
  3. #3
    Quote Originally Posted by pvanv View Post
    Thank You, The O-Ring #19 actually comes with a larger ring plus about 4 smaller ones in a kit. Can this be building up to much pressure for some reason? I'm not sure where the other O-Rings go, I was trying to figure out how to pull out the shaft, but looking at the part diagram it doesn't show anything below the piston. Like I had mentioned it was going up and down great no leaks until I added more fluid, which now I think may have been to much, because like a dummy wasn't thinking I had it laying on its side, I know they are to help self bleed air but not fluid, so I'm thinking of buying another O-Ring, there is a bearing shop close by that has all types O-Rings, and try it again. The alluminum ring that the shaft goes through and there holes in it where the fluid goes in and out/
    Thanks Again
Similar Threads
  1. Nissan NS 50D2 Trim/Tilt motor
    By jtbooch in forum Nissan Tohatsu Outboard Forum
    Last Post: 08-02-2012, 09:16 AM
  2. Power trim and tilt
    By azbirddog in forum Mercury Mariner Outboard Forum
    Last Post: 06-27-2012, 07:05 PM
  3. Older Nissan Tilt Trim 7090 hp 1987 aprox
    By sfreeman in forum Nissan Tohatsu Outboard Forum
    Last Post: 07-07-2009, 10:01 AM
  4. Power Tilt amp Trim
    By Bruce Ca in forum Yamaha Outboard Archive
    Last Post: 01-21-2008, 08:02 PM
  5. Power tilt and trim
    By kfish2 in forum Johnson Evinrude Outboard Archive
    Last Post: 05-02-2006, 06:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
