Hello all,
Does anyone know if there is a aftermarket fuel line that runs from the fuel pump to the carb that isn't copper? I need to find a replacement and can't find anyone or anywhere that sells the copper setup.
I believe the fuel pump outlet is a 5/16 fitting and the 1409 carb inlet is a 3/8 fitting.
Is it as simple as buying flared fittings and bending my own? Do I need specialized copper tubing or will anything go? All the one's I could find are for hvac use.
What size tubing will I need?
Much appreciated.
Much appreciated.
