Click for Chrysler parts and manuals!
Results 1 to 3 of 3
Thread: 318 Fuel line
  1. #1
    Default 318 Fuel line
    Hello all,
    Does anyone know if there is a aftermarket fuel line that runs from the fuel pump to the carb that isn't copper? I need to find a replacement and can't find anyone or anywhere that sells the copper setup.
    I believe the fuel pump outlet is a 5/16 fitting and the 1409 carb inlet is a 3/8 fitting.
    Is it as simple as buying flared fittings and bending my own? Do I need specialized copper tubing or will anything go? All the one's I could find are for hvac use.
    What size tubing will I need?
    Much appreciated.
  2. #2
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,238
    Default Re: 318 Fuel line
    Ayuh,..... I use automotive 3/8" steel brake lines myself,....
  3. #3
    Quote Originally Posted by crashband View Post
    Hello all,
    Much appreciated.
    Recently went through this drill with my 71' LM 318. Steel in tough to bend. I don't have the skill or patience. There is now a an alloy (copper, nickel etc) used for brake and fuel lines. Much easier to bend and flare. Available on ebay or most auto parts store. But I didn't use it. I ran Marine grade 5/16' fuel line from the carb to fuel pump, fuel pump to filter, filter to tank. My carb is a Carter AFB. Factory steel line was bent and crimped and needed replacing. At the carb I screwed in a 5/16" barb brass fitting and attached the 5/16" fuel line. The line runs forward over the intake manifold and down to the fuel pump between the head and alternator. Yes your fuel pump has 5/16" fittings. As I recall one of the pump fittings is screwed on.
    Buy your fittings from an auto parts store. I understand there is a threading difference between the plumbing fittings at Home Depot.
Similar Threads
  1. 98 johnson 35 hp electric fuel primer fuel line routing
    By daxon in forum Johnson Evinrude Outboard Forum
    Last Post: 07-22-2014, 04:50 PM
  2. Replies: 1
    Last Post: 06-23-2011, 02:41 AM
  3. Yamaha no fuel from main engine IO fuel line
    By nmaclean in forum Yamaha Outboard Archive
    Last Post: 07-09-2008, 04:48 PM
  4. Fuel water separator or just fuel line with filter on AQ125B
    By Javier Cubero in forum Volvo Penta Gas Archive
    Last Post: 10-17-2006, 08:39 PM
  5. 45hp classic 50 wonbt rev and no fuel from fuel line
    By bigblock454 in forum Mercury Mariner Outboard Archive
    Last Post: 09-06-2006, 09:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
