Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 2 of 2
  1. #1
    Default 1999 40 hp force
    Hi guys, I have a 1999 40 hp force motor on a 16 foot smoker craft stinger. The motor starts and runs perfect until about 3/4 throttle. After that you can start to hear and feel some hesitation almost like a slight sputter. if i slow back to 3/4 throttle runs absolutely perfect. I took the carb off and blew air through jets and nozzle and replaced it and no change. I never looked to see what jet size was in the carb. I dont have a tach on it to look at rpms either. It does have good compression in both cylinders and new plugs. I will be replacing fuel filter next time out. Could this be the float in carb not being set right? if so how can i check that? what about timing? Also what about fuel pump could it cause symptoms like that. The boat has a built in fuel tank with squeeze bulb in the line. Maybe its time to replace that line but there is no sign of leaks in line anywhere
  2. #2
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,513
    Default Re: 1999 40 hp force
    That could be: dirt in carb, jet clogged, fuel line, fuel filter, inline connector(has rubber in it), squeezie, pump, tank vent hose partially clogged,
    You new to this boat/ motor?
    Did it run ok before?
    88 Bayliner with 2002 225 HP Mercury EFI
    Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
    ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
    In Scenic , Beautiful San Sebastian by the sea Florida
Similar Threads
  1. 1999 40 hp force prop
    By busa in forum Chrysler Force Outboard Forum
    Last Post: 04-25-2017, 05:49 AM
  2. 120HP 1999 Force fuel feed problem
    By markp in forum Chrysler Force Outboard Archive
    Last Post: 06-03-2008, 08:44 PM
  3. 1999 Force 120hp
    By Arron Peterson in forum Chrysler Force Outboard Archive
    Last Post: 05-18-2008, 09:52 PM
  4. 1999 Gamefisher Force by Mercucry shuts off on accelerate
    By fulltick in forum Archive 2003-2009
    Last Post: 05-02-2006, 11:59 AM
  5. 1999 50hp Force By Mercury Trim Tilt
    By Jim Cowgill in forum Mercury Mariner Outboard Archive
    Last Post: 12-16-2003, 10:39 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
