chrisaaron
Greetings, searching these forums and many others trying to get help on this issue. First in Philippines where no service is available.
Friend has brand new BF225 (few years old but was in storage and just installed for first time). Initial start up alarms which we then followed procedure for pulling codes. Fault code 26 every time. We reset codes and started motor, however the overheat alarm stays on without audible alarm present. Ran the boat a bit and no overheating issues, seems to run perfect.
At wits end as after clearing the alarm on ECU it will come back again right after key on (motor stopped and started again).
Again this is a brand new motor which was installed with factory gauge panel and wiring harness.
Anything at all as were getting a bit desperate here and hoping to actually get some fishing in before typhoon season kicks in.
Cheers
Cheers
