Click for Chrysler parts and manuals!
Results 1 to 2 of 2
  1. #1
    Default 318 running hot !! Help !! ??
    We're just about to give up here. We bought a long block from Rapido marine ... REVERSE ROTATION... starboard motor is running hot will get to about 160 170 at dock when running hard (1/2 ton3/4) throttle she'll get to 200+ and slowly climb if we don't back her down.... back off throttle she'll cool down ... new freshwater Bi direction pump new raw water pump heat exchangers were done at rad shop all hoses replaced new thermostats (even tried drilling holes in them) new intake gaskets 50/50 antifreeze swapped heat exchanger didn't. Make a difference good flow through v drive sea cock good new exhaust manifolds they are about 120* when runnin hard good flow out the back of boat . When checked timing with a digital light it's saying we have 17* at idle and 37* total which is a lil high but we were told from a race car guy (someone who drives straight for 10 sec haha) that it still won't make it run that hot but we're going to try and take some timing out of it tonight as people are saying that's not true.... the motor runs strong when asjusting it seems to run worse but other than that we don't know what else to do unless something in the engine is blocked we did flush block best we could with. A garden hose when we had freshwater pump off anything will help please and thank you
    jack
  2. #2
    Join Date
    Mar 2008
    Location
    Bruford SC , U.S.A.
    Posts
    325
    Default Re: 318 running hot !! Help !! ??
    What happened to fastfred.....??? Sell the Marietta....???
Similar Threads
  1. 3.7lx 470 best running rpm
    By fishy1 in forum Mercruiser Sterndrive Forum
    Last Post: 01-28-2016, 12:44 PM
  2. Merc 9.9 stopped running while running at trolling speeds (gas starvation..
    By Ron J in forum Mercury Mariner Outboard Forum
    Last Post: 06-11-2013, 11:32 PM
  3. Running out of gas
    By rick_taylor in forum Johnson Evinrude Outboard Archive
    Last Post: 08-10-2009, 10:33 AM
  4. 454 Running hot
    By norcalnordic in forum Mercruiser Sterndrive Archive
    Last Post: 07-06-2009, 02:04 PM
  5. DT 140 running hot
    By capt_tony in forum Suzuki Outboard Archive
    Last Post: 05-06-2009, 09:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
