Mark gives you some excellent suggestions. Take heed!
You may also want to try using the P of E...... process of elimination. You have twins, so this adds a level elimination!
Map out your ignition advance on both engines, and within the usable RPM range. Use engineering paper and make line graphs!
In other words, look at the "progressive" advance as per RPM, and the "total" advance as per RPM and plot this out on paper.
The two ignition advance curves must be the same (or extremely close)!
Try swapping Port/Stbd caburetors.
Also try swapping the Port Floscan sensor for the Stbd unit..... and visa-versa.
See if the odd fuel consumption reading follows any of the above component swaps!
