Results 1 to 4 of 4
  1. #1
    Default PCM 40a slipping in forward
    I have a PCM 40A 1.23/1 transmission in my 96 sport nautique. It began slipping in forward but not in reverse. Changed the clutch plates and seals. It still is slipping. Once you have enough throttle it will go into gear until you slow down. Pressure problem? Any way of adjusting the oil pressure?
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,386
    Default Re: PCM 40a slipping in forward
    sounds like not enough pressure coming out of the pump....did you go thru the pump while the gear was apart?
  3. #3
    Quote Originally Posted by makomark View Post
    Looked at the pump gears but didn't see anything obviously wrong.
  4. #4
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,386
    I can't say I've read the PCM spec but 'looking at them' doesn't assess all aspects of wear.....besides the pump, the only remaining items would be the control valve (usually not an issues as long as the cable hasn't been altered) and the pressure regulating device....I think getting a hose and pressure gauge out would be a good start...
Similar Threads
  1. 90 Hp Mariner Slipping in forward and reverse
    By Chris E. in forum Mercury Mariner Outboard Forum
    Last Post: 05-14-2010, 03:58 PM
  2. Slipping in forward Nissan 2stroke 8hp
    By feltensteingw in forum Nissan Tohatsu Outboard Forum
    Last Post: 06-25-2009, 08:09 PM
  3. 200XS Forward Slipping
    By kparker_kp in forum Mercury Mariner Outboard Archive
    Last Post: 07-16-2007, 12:43 AM
  4. OMC Cobra 43 slipping out of gear when going forward
    By David Boatwright in forum OMC Sterndrive and Inboard Archive
    Last Post: 06-04-2006, 07:44 PM
  5. b85 Mercury 35hp slipping out of forward
    By zuidema in forum Outboard motors archive 2000-2004
    Last Post: 08-05-2001, 09:11 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
