Results 1 to 2 of 2
  1. #1
    Default 1977 70 hp seahorse exhaust baffle
    New to boat repairs. I have a 77 johnson 70hp. I bought it a couple weeks ago, hit the water and cylinder filled up with water. I changed head gasket had the head milled. Still filled up so I removed the exhaust cover and manifold . Is it possible to replace the baffle and manifold without removing powerhead?
  2. #2
    Join Date
    May 2011
    Location
    slough ,berkshire uk
    Posts
    161
    Default Re: 1977 70 hp seahorse exhaust baffle
    yes it is
    these are prone to warping, lots of people have replaced these.
    but do make sure the block where the plate joins has not corroded !!!
Similar Threads
  1. Torque pressure for exhaust manifold and baffle for 1976 115 hp merc outboard
    By Mark W in forum Mercury Mariner Outboard Forum
    Last Post: 11-15-2016, 08:22 AM
  2. Should this hose go anywhere? '1977 Seahorse 55hp...(pic also)
    By wolf66 in forum Johnson Evinrude Outboard Forum
    Last Post: 03-24-2011, 12:57 AM
  3. Mercruiser exhaust baffle replacement
    By glenn allen in forum Mercruiser Sterndrive Archive
    Last Post: 08-05-2007, 07:59 PM
  4. 1977 15hp johnson seahorse
    By Ryan kessler in forum Johnson Evinrude Outboard Archive
    Last Post: 09-01-2006, 09:16 PM
  5. Zinc on a 1977 Johnson 35 hp Seahorse
    By maw77712 in forum Johnson Evinrude Outboard Archive
    Last Post: 08-24-2006, 05:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
