Results 1 to 3 of 3
  1. #1
    Question 1987 225 Evinrude on 1987 Wellcraft 250 Coastal
    Can anybody suggest a prop for this setup? I do not have one yet.
  2. #2
    Default Re: 1987 225 Evinrude on 1987 Wellcraft 250 Coastal
    I just read my own question and I did not give enough info. This motor(225 Evinrude I think it's a late 80's) has no prop. The boat(25'Wellcraft is about 3900lbs.) will be used primarily for fishing, so 3-4 people and 50 or more gallons of fuel. I got the motor without a prop and I haven't run it yet. I tried contacting Wellcraft, but I got no answer. If this engine runs at
  3. #3
    Some info from my last post wasn't saved. If this motor run's at say 4800-5200 using role of thumb 1" to 200 rpms would be a 24"pitch. I was thinking a 14-15" diameter with a 17" pitch sounds like a place to start. Can any body please help?
Similar Threads
  1. 1987 wellcraft 190 engine question..
    By SLACK in forum Mercruiser Sterndrive Forum
    Last Post: 07-10-2016, 01:27 PM
  2. 1987 Evinrude XP 150
    By crappymad in forum Johnson Evinrude Outboard Forum
    Last Post: 03-18-2016, 09:30 PM
  3. My first boat! 1987 Wellcraft 192 Classic with OMC Cobra 4.3L
    By Neonzion in forum OMC Sterndrive and Inboard Forum
    Last Post: 08-14-2013, 10:53 PM
  4. 1987 Evinrude 70 h.p.
    By Dunc in forum Johnson Evinrude Outboard Forum
    Last Post: 05-05-2011, 10:02 PM
  5. 1987 Wellcraft Potofino dash Switch Panel
    By mramont895 in forum Archive 2003-2007
    Last Post: 03-05-2006, 12:25 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
