Click for Chrysler parts and manuals!
Results 1 to 4 of 4
  1. #1
    Default 1976 CHRYSLER 400 Where do I connect hoses for water heater?
    I have a 1976 Trojan with a single Chrysler 400. The vessel has never had a water heater. Currently installing, and was wondering where to connect the supply and return hoses on the engine. Suggestions?
  2. #2
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,538
    Default Re: 1976 CHRYSLER 400 Where do I connect hoses for water heater?
    Ayuh,.... Ya need a 1/2" port usually in the intake manifold for a hot water feed, 'n a 1/2" return port, usually in the circultin' water pump housin',...
  3. #3
    Both hoses go to the water pump housingClick image for larger version.
  4. #4
    Join Date
    Dec 2006
    Location
    Posts
    5,538
    Ayuh,.... The water pump housin' is the low pressure point, with the coldest water,....
    You need to tap into the motor, Before the t-stat for the hottest water at the highest pressures,...
Similar Threads
  1. Remove hot water heater hoses from engine
    By Floatation Device in forum Mercruiser Sterndrive Forum
    Last Post: 06-08-2013, 10:51 AM
  2. How/where to plumb/connect hot water heater to gm 350/260
    By jlipe in forum Mercruiser Sterndrive Forum
    Last Post: 08-05-2012, 01:01 PM
  3. Heater Hoses
    By Bullnose in forum Miscellaneous marine engine topics
    Last Post: 11-20-2011, 11:09 AM
  4. (1994 150 faststrike)?? where do these hoses connect to
    By frank arnold in forum Johnson Evinrude Outboard Forum
    Last Post: 05-18-2010, 11:18 PM
  5. Water hoses Chrysler 360
    By dawilson76 in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 08-15-2008, 06:06 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
