I recently purchased this boat and the oil injection appears not to be working. I am running off a premix tank and every time I put oil in the main tank and run the motor the oil siphons out and runs on the ground after I am home. I replaced the 2psi check valve and still runs out the vent . I have decided to remove the system. I have seen where there is a kit available to do this. where is it available.
