Results 1 to 2 of 2
    Default Main Breaker pops
    I have a marine power 350 carbureted engine. When the engine is cold and I start the engine it starts fine runs for a minute or two then pops the main breaker.. I turn the key off and reset the breaker and everything starts and works fine with no problems after that... I check the obvious things like tight connections plugs seated correctly etc. What would draw that much only on startup? Sticky relay somewhere?
    CSM
    Sep 2008
    Maryland - USA
    7,184
    Default Re: Main Breaker pops
    It could be the breaker is failing.....I'd suggest using a clamp on DC amp meter to verify the current draw is excessive....
    Usually, the alternator is a likely suspect - its one of the few things connected directly to the +12VDC main line.....
  1. 275 pops out of fwd gear
    By hayescages in forum Volvo Penta Gas Engine Forum
    Last Post: 07-29-2014, 11:04 AM
  2. Gear pops out when put in reverse?
    By scoobs222 in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 05-29-2012, 07:11 AM
  3. chrysler 318 pops after 2100 rpm
    By Chrispy12111 in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 05-23-2010, 03:41 PM
  4. DT 99 pops out of reverse
    By Charlie H. in forum Suzuki Outboard Archive
    Last Post: 05-08-2008, 11:52 AM
  5. Motor pops out of gear
    By paddfam in forum Johnson Evinrude Outboard Archive
    Last Post: 07-09-2007, 12:28 PM
