Results 1 to 3 of 3
  1. #1
    Default What Kind Of Outboard Are These Control Cables For?
    Hello! Recently purchased a 94 Osprey Center Console. The Control cables that were in use are still with the boat. If I understand correctly different outboards use different cables? If that is true and I can identify what make of outboard these cables are for maybe I can save some money. I've attached a few pictures. Can anyone tell me what brand of outboard these cables are compatible with?
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	15595   Click image for larger version.
ID:	15596   Click image for larger version.
ID:	15597   Click image for larger version.
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,399
    Default Re: What Kind Of Outboard Are These Control Cables For?
    the ends of those cables (look like Morse) can be swapped for whatever you want to mate them to.....the electrical harness is usually make specific....look up at the 'key end' and you're likely to find the OEM part number for the harness assembly.....
  3. #3
    Quote Originally Posted by makomark View Post
    Thanks Mark!
Similar Threads
  1. can I use mercury control cables on a honda outboard
    By 1gumbi in forum Mercury Mariner Outboard Forum
    Last Post: 11-07-2014, 12:56 PM
  2. Remote control cables
    By Skooter in forum Honda Outboard Forum
    Last Post: 05-28-2014, 07:19 PM
  3. Replies: 0
    Last Post: 04-30-2014, 10:21 AM
  4. Control cables
    By bowend in forum Johnson Evinrude Outboard Archive
    Last Post: 01-19-2009, 08:56 PM
  5. Yamaha control box Omc cables
    By GAR in forum Outboard motors archive 2000-2004
    Last Post: 07-20-2002, 01:58 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
