I havent owned a boat fir many years but got a great deal on my neighbors 1993 Harris Flotebote with a 4 cyl 3.0 iron duke engine and Yamaha outdrove . I think it may be called a stern drive but not sure . I'm a bit confused but anyway I got the boat running , my buddy rebuilt the carb and it runs great at idle and when it's in neutral and will run great once you put in gear and just go . The problem is when you want to slow down and stop and you try to shift from forward to reverse or vice versa and even from forward to nuetral it will die . Starts right back up and will go but if you try to switch back to reverse it dies . Makes it very hard to dock or go slow in the water
Tjanks so much for your help in this matter. Tom
