Results 1 to 17 of 17
    Sep 2008
    pensacola, fl, us
    184
    Default Hurth ZF output seal leaking
    1995 ZF63C/HSW63IV coupled to Crusader 454XL (1000 hrs) in a 1995 Trojan 350 Express. Just removed port engine for re-build. After re-installing engine and gear box after rebuild, did sea trials and NO leaks. After three days, I checked for leaks and noticed ATF under V-Drive out put seal. Questions: Can a seal be replaced with V-drive in boat? I will haul boat to move shaft, but I don't want to remove engine again. Also, any thoughts on using
    ATP At 205 or like product for a temporary fix??
    Sep 2008
    Maryland - USA
    7,304
    Default Re: Hurth ZF output seal leaking
    Bummer on the leak.....If you had somebody overhaul the gear, I'd be inclined to ask them about the leak...
    You can change the seal in the boat if you can get to it.....not knowing the cause would suggest caution in guessing at the fix.... there is no magic in a bottle that works as a temporary fix...
    Sep 2008
    pensacola, fl, us
    184
    I did the rebuild myself. The v-drive was not touched except to remove and replace it and a little paint touch up. I looked in my ZF gear box manual, and it looks like I have to pull the vdrive apart in half. If that's the case, gotta pull engine again (wife will not be happy) if I can replace seal just by removing coupler, I can do it in the boat.
    Cause is unknow, when replacing shaft (twice) did I hit/knick seal?? Don't think so. Shaft is straight and alignment is perfect. When doing paint touch up did I get paint on seal?? maybe
    Sep 2008
    Maryland - USA
    7,304
    got it - gear wasn't touched but for the paint....
    I'm pretty sure you don't have to open up the housing to change the seal - getting to it is gonna be the tough part....a bit unusually in that the leak was 'delayed'....how bad is it leaking and are you sure its the ouput shaft seal?
    Sep 2008
    pensacola, fl, us
    184
    MakoMark,
    Thanks for helping. Just about positive its the output seal on the coupler side of drive. I slid a oil absorbant pad between coupler flange and seal. leaking for sure. I have read and re-read service manual (You sent me manual years ago) I keep seeing where you have to open housing and remove gears to replace seals. There is a shop near by that will fix it, 4-6 weeks out. At $25.00 day on hard, I see new gear boxes for around $3k. Hurth/ZF 63C/HSW63 lV SER # 17 11358
  6. #6
    Sep 2008
    Maryland - USA
    7,304
    I don't think its essential to separate the cases - just easier....if you're gonna bite the bullet, I'd suggest getting them to renew all the seals while its out....
  7. #7
    Sep 2008
    pensacola, fl, us
    184
    Just ordered a seal kit. Im gonna do it myself. Will replace all seals and gaskets. Its one of those "a nickel part is going to cost a dollar" The seal kit was $100.00. By time I pay for haul out, lay days, and boom truck, it will be a $ a grand!! I will let you know when all done. It will be a couple weeks, got a lot on the plate now.
  8. #8
    Sep 2008
    Maryland - USA
    7,304
    i know exactly what you mean.....the 'short haul' concept around here borders on criminal.....but, when everybody decides to get greedy, you pays or you sit on the couch....
    good luck!!
  9. #9
    Sep 2008
    pensacola, fl, us
    184
    Still have not gotten to the seal project. We are now dealing with a tropical storm and rain for ever. No boating anyway. maybe after the forth of July I will get the Trojan hauled. Until then, its the pontoon boat for our boating fun!!!!
  10. #10
    Sep 2008
    Maryland - USA
    7,304
    I was thinking about your project when I saw the wx clips on the news this morning....fingers crossed...
  11. #11
    Sep 2008
    pensacola, fl, us
    184
    Just a little update on the leaking seal. I went to a local Hurth/ZF dealer and he said he would reseal the v-drive for $1000.00. After banging the net, I called a Hurth/ZF dealer in Alabama and drove over there yesterday.. Very nice clean professional operation. They ordered a new complete V-drive for 2 grand. shipping tax out the door. Will let yall know when haul out and replacement happens. hopefully in a couple weeks!!
  12. #12
    Sep 2008
    Maryland - USA
    7,304
    that's one way to git er dun!!hope the wx cooperates for you.
  13. #13
    Sep 2008
    pensacola, fl, us
    184
    I have a haul out scheduled for this Wednesday. I hope to be back in the water Friday with new V-drive and manifolds and elbows. Its lookn like we might get some boating in this summer after all!!
  14. #14
    Sep 2008
    pensacola, fl, us
    184
    I pulled the boat this morning. Boom truck was right on time and got the engine and V-drive pulled out of boat by noon. Took old v drive off, put new one on and had engine and new v-drive back in boat before the yard personal knocked off. tomorrow I will button everything up and I have a 1200 launch Friday. So far, so good. Just hot as crap here. Over 100 and no shade in a boat yard!!!! Don't think that first beer this afternoon didn't taste good!
  15. #15
    Sep 2008
    Maryland - USA
    7,304
    Glad you are over the halfway point - hope you get it wrapped up today.
  16. #16
    Sep 2008
    pensacola, fl, us
    184
    DONE!!!! Got boat home. One little issue. ATF in bilge. The crush ring on the pressure sender was CRUSHED. got new one and all is fine. Going boating today and we will be back Monday maybe Tuesday! I will reseal old vdrive this winter and either keep it or list it
  17. #17
    Sep 2008
    Maryland - USA
    7,304
    how was the trip?
    guess you have Irma prep to do now? Hoping for the best there...
  1. YSE12 How to change the oil seal on output shaft
    By seanreid71 in forum Yanmar
    Last Post: 03-20-2016, 04:12 PM
  2. Mercury thunderbolt 500 output shaft oil seal change-help!
    By Cptsnd in forum Mercury Mariner Outboard Forum
    Last Post: 08-13-2015, 10:11 AM
  3. Transmission output seal leaking - post rebuild
    By bobct in forum Crusader Marine Engine Forum
    Last Post: 06-25-2014, 06:15 PM
  4. Borg Warner v-drive output shaft seal leaking
    By fiveoclocksomewhere in forum Crusader Marine Engine Forum
    Last Post: 03-24-2013, 03:44 PM
  5. 165 sterndrive seal leaking
    By daveolejnik in forum Mercruiser Sterndrive Archive
    Last Post: 05-16-2007, 11:16 AM
