Click forPleasurecraft Marine parts and manuals!
Results 1 to 4 of 4
    Default Low pressure fuel pump inlet screen
    Does anyone know if there is an inlet screen on the low pressure fuel pump of the 2001 5.7 HO TBI? Do you remove the 90 barb to access?
    Sep 2008
    Maryland - USA
    7,158
    Default Re: Low pressure fuel pump inlet screen
    dont think there any screen on the low pressure pump....wont hurt to look....there a big filter inside the FCC can....
    Quote Originally Posted by makomark View Post
    Thanks! Yes, I think I read somewhere, no screen, but on other similar setups ive read there are. I may just have to look. Just try not to mess with stuff if I don't have to. I've a long history of tinkering with things and they mysteriously break, .
    Quote Originally Posted by Maraian View Post
    Sorry for the late reply but there is a screen on the inlet side of the low pressure pump. My 2002 PCM 5.7L (MB Sports 190 Inboard) was blowing the fuel pump fuse and I discovered the screen was plugged with fiberglass debris from the fuel tank.
    Cleaning the screen didn't resolve the issue so I ended up replacing both the low pressure pump as well as the Fuel Control (high pressure pump)
    But you CAN clean the screen, re-assemble and see for yourself.
  1. What does a man have to do to get a Tillotson fuel pump inlet to quit leaking?
    By hotrod53 in forum Mercury Mariner Outboard Forum
    Last Post: 06-19-2011, 09:35 AM
  2. 1978 Merc. 90hp fuel pump inlet cover??
    By fixitdaily in forum Mercury Mariner Outboard Forum
    Last Post: 03-27-2011, 02:45 AM
  3. Round silver ball on the inlet side of the fuel pump
    By rockdoc in forum Crusader Marine Archive
    Last Post: 07-27-2009, 03:00 PM
  4. Water inlet screen for Mercury outboard
    By kimberly_anne in forum Mercury Mariner Outboard Archive
    Last Post: 11-05-2008, 05:05 PM
  5. 1972 50HP FUEL PUMP WITH FILTER SCREEN
    By stma12 in forum Johnson Evinrude Outboard Archive
    Last Post: 04-05-2006, 07:04 AM
