Results 1 to 4 of 4
    Question Cummins QSB5.9 engine does not start
    I have a QSB5.9 cummins engine,it was working perfectly. After several starts and stops, now the engine does not want to start and has a sound alarm.
    Anyone know what can it be?
    Jun 2008
    557
    Default Re: Cummins QSB5.9 engine does not start
    It can be a lot of things but my first check would be the fuel filters and to reprime the fuel system. After that you could be looking at lots if different sensors but a complete no start rather than poor running would make me check the crank angle sensor as one of the first thoughts.
    Hi. Thanks for your help, I will start the diagnosis by that sensor,I was looking for the wiring diagram of cummins QSB 5.9 but I only got the cummins ISX, is it the same?
    Thanks for everything
    Good morning, please someone can tell me where to find, the following documents: QSB 5.9 CM850 Smarcrft 2.x Wiring Diagram
    Thank You..
  1. cummins engine and parts
    By Charles Jiang in forum Cummins
    Last Post: 01-31-2016, 01:34 AM
  2. CUMMINS 6 BTA 5,9 water inside of engine
    By ALAR in forum Cummins
    Last Post: 07-26-2012, 10:46 PM
  3. Replies: 1
    Last Post: 03-13-2008, 02:35 PM
