Results 1 to 6 of 6
  1. #1
    Default Vibration from mount failure or timming issue
    Is there an easy way to tell if vibration is caused by mount failure or a timing issue.
    On a separate issue may or may not be related....
    the manual has the firing order as shown however the firing order on the boat is as shown in red
Name:	firing order.jpg
ID:	15555 Click image for larger version.
Name:	Inkedfiring order_2.jpg
    same sequence just different locations (out by one counter clockwise) on the distributor cap...
    here's a link to the engine run;
    https://youtu.be/-E5fI4-lPs4
    I appreciate all feed back.
  2. #2
    Join Date
    Apr 2010
    Posts
    4,129
    Default Re: Vibration from mount failure or timming issue
    Do a cylinder drop test on it and see how it's firing on each cylinder.
  3. #3
    So i gave it a whirl all sparks are good, still rough, so this may be a dumb question but I don't remember my last boat vibrating or the motor shaking the boat is there going to be vibrations.
  4. #4
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,475
    Ayuh,.... It's skippin', 'n stumblin', not runnin' smoothly,.... also idlin' high,....
    It should idle dead smooth at 650/ 750 rpms,.... no surging,..
  5. #5
    Join Date
    Oct 2012
    Location
    sacramento, ca.
    Posts
    306
    bring it up to TDC......., pull the cap off and look where the rotor is pointing. that is number one. (if you did not pull the distributor). even if you did, and it is at TDC, but pointing in a different location, that is ok, just put number one wire in that location, and continue with the firing order. is does not matter where the rotor is pointing when it is at TDC. just sync the firing order with that location.a lot of people will say that the rotor has to "point to number one". they get that confused with number one location of where you want number one wire at on the distributor. the distributor could care less where it is pointing, as long as it is firing the correct plug.
    *** In comparing the virtues of various calibers, using hollow point ammo: it is absolutely undeniable that, while a 9 mm or .40 S&W may or may not expand, a .45 will never shrink. ***
  6. #6
    Join Date
    Jan 2016
    Location
    San Pedro CA
    Posts
    328
    unless you had a cam change the firing order should be stamped on the intake manifold. Remove plug #1, rotate motor till its about 45 degrees from the ) mark. Put finger over plug hole and seal it 99%, turn motor over - if a firm stream of air is pushing past finger you are on the compression stroke - rotate to 0 mark and make sure distributor rotor is pointing at the wire for that plug.
    If no air you are on the exhaust stroke - rotate crank 180 degrees and repeat the finger test - turn till on 0, check rotor is pointing to where the #1 plug lead goes on cap.
Similar Threads
  1. Heat exchanger mount vibration
    By bobct in forum Crusader Marine Engine Forum
    Last Post: 09-15-2016, 01:40 PM
  2. Vibration issue
    By det352 in forum Mercury Mariner Outboard Forum
    Last Post: 10-04-2014, 09:04 AM
  3. vibration issue - new mounts last year
    Last Post: 05-15-2014, 07:57 AM
  4. Vibration issue
    By Ngeogh in forum Crusader Marine Engine Forum
    Last Post: 06-09-2012, 02:51 PM
  5. honda 2002 225hp vibration issue
    By aristakat in forum Honda Outboard Forum
    Last Post: 09-12-2011, 06:54 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
