i am having the same problem with my 2013 4 stroke 115hp cant get the prop shaft out from the forward gear. I hit a rock and pushed in the front of the bottom end very slightly. Have removed bottom end and shifter rod, reverse gear and carrier but cant get the prop shaft out. I could remove pinion gear however it would not allow me to remove it as the prop shaft clutch will be in the way and not allow me to pull the prop shaft and forward gear out as one unit.
If the prop shaft is supposed to come out from the forward gear without much effort i will assume there is something damaged behind the forward gear not allowing the prop shaft to be removed.
I have tried about everything but force unless there is a special way to remove the prop shaft
Need help form someone please before freeze up here in Canada
