My f80 2003 ran fine last trip. Now throttle will not advance more than just past idle. The engine starts and runs fine. Disconnected cable and see that the issue is with carb lever, not the remote or cables. Seems like the connection that goes up to the 4 carbs simply won't budge. Disconnected the pushrods ball link between the two moving bellcranks and the front lever moves freely, the rear one that connects up to the carbs moves only a small bit. The arm protruding into the cutout in the middle of the lever should probably move around in this hole, but does not. Help appreciated. Henning
