Results 1 to 7 of 7
    Default i want a nicer trailer
    The galvanized one I have now spent a lot of time time on the coast so rust is holding everything together. I've seen some very nice trailers for $300 but some only have bunks while mine has rollers too. My boat is a light 16 ft aluminum vee hull, dry weight 250-275 lbs. Could a bunk only work ?
    Default Re: i want a nicer trailer
    This is a 22ft example. The bunks are adjustable but no rollers.
    Sep 2008
    Maryland - USA
    8,070
    my catfishing buddy has a similar boat with a single bunk on each side trailer.....it works but usually dictates the boat get 'floated off'. this, of course, isn't the best for the logevity of the trailer....he's ok with it but doesn't use the boat "frequently" (maybe 15 trips a year). My opinion is a trailer with properly adjusted rollers is worth every dollar it will cost you....if your current trailer frame is near end of life, you can always consider saving its rollers and using them on a new frame...
    The one in the pic had a 20 ft i/o bay boat on it. Seems like heavy boats like that would need rollers more than mine would.
    Sep 2008
    Hague, Virginia, USA
    4,690
    A friend has a light boat like that and uses the slick silicon-type bunks that lets it slide into the water pretty easily. On a steep ramp, he has to use the winch to control the slide. Just make sure you use good tie-downs front and rear during transport.
    CHawk 25 DLX
  6. #6
    I wound up with a smaller trailer closer to home and fixed it up, then ran into the non-title nightmare NC is famous for.
  7. #7
    If you are still looking for the trailer under $300 then either you can opt for Nicholson 1500 or Bunk trailers. If you still find yourself in confusion then consulting a person who has deep knowledge in buying the trailers can help you. My cousin also did the same, by consulting the head of auto transport West Palm Beach service he finally purchased an NT3500 Roller trailer. You can also go the same way if you are comfortable with my suggestion or else can choose the other options too.
  1. Looking for a new trailer jack
    By DWester in forum Boat Trailers - Repair, Parts & Advice
    Last Post: 06-11-2015, 04:32 PM
  2. Trailer question
    By fishon10 in forum Mercruiser Sterndrive Archive
    Last Post: 04-30-2008, 11:16 AM
  3. Trailer Brakes
    By zumbadora in forum Mercruiser Sterndrive Archive
    Last Post: 04-28-2008, 04:23 PM
  4. Trailer tires dry rot
    By dave_kirk in forum Archive 2003-2007
    Last Post: 10-24-2007, 08:20 AM
  5. Trailer Brakes Anyone
    By guyjg in forum Mercruiser Sterndrive Archive
    Last Post: 10-23-2007, 06:39 PM
