I had to replace my distributor, I marked everything as best I could. The engine does start right up and seems to run pretty well after the replacement.
I located an engine wire harness connector labeled "Diagnostic / depth-finder". It is a four pin connector.
My questions;
How do I disable the electronic timing advance to set base timing?
I'm guessing that since there is only a TDC mark on the timing cover, the timing needs to be set at "0 deg's"??
Any words of wisdom will be greatly appreciated!!
Respectfully, WES
My questions;
Respectfully, WES
