Steveevans
Hi
i have just finished rebuild my boat engine and am now trying to get her running.
The engine turns over and firer but run really rough. I have to keep the choke pretty much shut.
Today I attempted to set the timing using a timing light and notice the patten was irregular on cyinder 1. I attach the timing light between the coil and distributor and notice I was losing the spark after about 20 seconds It would sometimes come back and other time just stall the engine.
I disconnect the grey cable to the tact and the white / green from cut out switch and the same thing happened.
Anyone got got any ideas what could be causing this to happen?
How can can I test the ignition sensor ? coil? And the ignition module?
Its it's almost like something is shorting to earth causing the ignition module to shut down.
I thank you all in advance for your help
cheers
Steve
cheers
Steve
