farmerrick53
I was looking to repair the charge circuit on my honda 100 (10hp) and the plug on the motor is broken, the coil works so I was wondering if anyone had a line on a plug harness for this. thanks.
Serial # might be needed
A difference in the last three digits of a Honda part number sometimes indicates a very minor difference in the part like a slightly different makeup in the material used. And other times the part seems perfectly identical to the one with the "superseded" number. I have to assume this is some sort of inventory control stategy.
But, since you're trying to source for an older engine, you may want to use the lower or superseded number. I really doubt though that it is going to make much difference since that part number's last three digits have probably been changed 20 or 30 times since your outboard was made.
Good luck
