Results 1 to 6 of 6
  1. #1
    Default help identifying
    i need help figuring out what year and model this engine is, was told it is a 1990 johnson 90hp. id plate is missing only numbers I could find are on the freeze plug. as follows thanks
    E100WTXCDR
    1150304
  2. #2
    Default Re: help identifying
    also I have an issue it seems like the bottom two cylinders aren't firing. the plugs look to be clean and wet when I pull the plug wires from the bottom two cylinders while engine is running I can hear the coils arching off something then as soon as the plug wire is put back on the acring sound stops
  3. #3
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    15,249
    CD makes this an 86 commercial 100 hp model.--------------Compression test will tell the story.----Likely a problem will quickly be found there.
  4. #4
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,928
    Run it at nite and look for the fireworks?
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  5. #5
    ran a compression test this eaving all 4 cylinders are at 90 psi seems low to me but odd that they are all at 90 together ?
  6. #6
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    3,141
    Also x=extra long shaft, wt=electric commercial tilt+trim, Fire it up in the dark as kim posted
Similar Threads
  1. Need help Identifying a 9.9
    By WHaven in forum Identifying Model / Year / Horsepower
    Last Post: 02-18-2016, 06:13 PM
  2. identifying the hp on a v8
    By newguy375 in forum Identifying Model / Year / Horsepower
    Last Post: 10-28-2014, 01:16 AM
  3. Identifying yr, hp.
    By Papioguy in forum Identifying Model / Year / Horsepower
    Last Post: 10-01-2013, 05:09 PM
  4. Help identifying
    By Dickey in forum Identifying Model / Year / Horsepower
    Last Post: 07-01-2013, 04:08 AM
  5. Identifying YH
    By keatonlover in forum Ford Interceptor Marine Engine Forum
    Last Post: 03-04-2009, 12:26 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
