Need your engine serial number to ensure the correct parts are found.
Did the sacrificial trim tab anode have a fin at the end of it? The fin will affect your steering at speed and the new one would need to be adjusted correctly to find the best overall steering pressure (< Lets call it) all the while the boat tracks straight forward. See item 43 for example, http://www.marineengine.com/parts/m.../gear-housing-propeller-shaft-2251-gear-ratio
https://www.perfprotech.com/blog/ma...ry-marine-outboard-motor-serial-number-number
Yes there should be a fin designed anode in place and it will help correct the steering issues you've mentioned above once it's adjusted correctly mostly by trial and error...Sort of common for them break off if hit, etc....It's item number 10 in "your" engine model number 1025207FL parts diagram. 853762 - Trim Tab0N093626
Never saw what used to be there it was like this when I bought it. No fin at all. Looks like it maybe was a trim tab?
