Click for Suzuki Manuals, Parts and Model Guides!
Results 1 to 13 of 13
  1. #1
    Default 1988 dt150 wont go
    1988 dt150 wont go after putting in gear, usually dies. runs/revs fine out of gear. idles a little low and rough. has good compression on all cyl's, new plugs, new fuel filter. its on a 24 foot pontoon. any help would be appreciated. thx
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,945
    Default Re: 1988 dt150 wont go
    All motors rev just " fine " in nuetral.------Do you have spark on all leads ?
  3. #3
    not sure, how would i check that while putting in gear?
  4. #4
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,945
    No need to put it in gear for that sort of test.
  5. #5
    Ok. Can I use a timing light to verify spark?
  6. #6
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,945
    That is one way to do it.---------Spark tester is best way.
  7. #7
    Ok thx for the help. I will post the results as soon as I can. Boat is 20 minutes away at the marina. Anything else I could check while I'm there?
  8. #8
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,951
    Pull one plug lead at a time with plastic pliers while she's running, If you get no rpm drop on a cylinder,you found the non running one
  9. #9
    well I went to the marina yesterday to run a few tests and pull the carbs and something else went wrong. I checked for spark on all 12 wires and all was good. ran a compression check and all cylinders had 120 psi. while checking for spark it was idling a little high then it started shifting/banging into gear on its own without touching the controls. did this a few times then it stopped but I couldn't make it go into gear with the controls. it also stopped pumping water so my beast guess is something happened to the lower unit. I'm going to get it back home this weekend and pull the lower unit.
  10. #10
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,951
    Pull plugs and see if engine can be rotated by turning flywheel by hand, If not time to pull l/unit
  11. #11
    driveshaft broke so I sold it.
  12. #12
    check water in vapor separator
  13. #13
    Quote Originally Posted by johnnygjr View Post
    Thanks for the tip, worked like a charm!
Similar Threads
  1. 1988 DT150 lower seal replacement
    By cds11 in forum Suzuki Outboard Forum
    Last Post: 11-02-2016, 12:53 PM
  2. 99 dt150 turnedoff wont turn on
    By arrowhead in forum Suzuki Outboard Forum
    Last Post: 05-24-2014, 01:34 PM
  3. 1988 DT150 was running great until I hit the trim button
    By rj377 in forum Suzuki Outboard Forum
    Last Post: 05-19-2014, 11:43 PM
  4. 1988 dt150 question
    By bfd300 in forum Suzuki Outboard Archive
    Last Post: 04-22-2009, 03:58 PM
  5. 1988 Suzuki DT150 issue
    By boatmadmaniac in forum Suzuki Outboard Archive
    Last Post: 12-01-2008, 12:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
