Results 1 to 13 of 13
  1. #1
    Default 15hp Johnson commercial
    Hi new here can't seem to get outboard running properly new fuel new plugs sometimes starts for a bit then won't start help please
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    13,962
    Default Re: 15hp Johnson commercial
    A model number helps.
  3. #3
    Sj15rps thanks
  4. #4
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    13,962
    That would be a 1995 model.-----------If the motor sat for any time then I would clean the carburetor.
  5. #5
    It's was running and stopped bottom plug wet put new plug in no different got it home new fuel new plugs still no joy
  6. #6
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    13,962
    Check for spark.---------Does primer bulb go hard , yes or no ?
  7. #7
    Yes bulb is getting hard and there's a spark
  8. #8
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    13,962
    Will that spark jump a gap of 3/8" or 1 cm , yes or no ?
  9. #9
    hi went to out board to check spark Very weak now nothing mate
  10. #10
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    13,962
    Your ignition system needs work done.
  11. #11
    What should I check first mate
  12. #12
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    13,962
    Do you still have strong spark on one cylinder ?---If so switch the ORANGE wires to the coils and report if now other coil has strong spark ?
  13. #13
    No spark off ether mate
Similar Threads
  1. 92 Johnson 155 HP Commercial OB plugs fowling
    By mstahl1171 in forum Johnson Evinrude Outboard Forum
    Last Post: 01-03-2016, 07:36 PM
  2. 1992 Johnson 155 Commercial J155WTXENE
    Last Post: 08-27-2015, 10:53 PM
  3. 1998 Johnson 100 hp commercial
    By truckerx in forum Johnson Evinrude Outboard Forum
    Last Post: 06-12-2013, 01:40 AM
  4. 1988 45 HP Johnson Commercial Outboard
    By bigcec in forum Johnson Evinrude Outboard Archive
    Last Post: 05-10-2009, 04:32 AM
  5. Johnson 9 hp commercial
    By sealandmaster in forum Johnson Evinrude Outboard Archive
    Last Post: 10-10-2007, 01:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
