Click for Suzuki Manuals, Parts and Model Guides!
Results 1 to 2 of 2
    Default Need help with 1985 DT 30 Remote control box
    Hi--new here. My Sea Scout Ship (part of the Boy Scouts) recently received the donation of a nice 1985 DT 30 for our 13' Boston Whaler. We found and bought an NA 12 S remote control so the scouts can learn how to shift gears and use a throttle. However, the throttle cable pulls in (moves forward) to accelerate, while the throttle bell-crank on the side of the motor needs to move aft to open the throttle (shifting works fine). What to do? Is this control box not compatible with our motor? Or can something be changed inside the control box or motor throttle control to make it work?
    Thanks!
    Default Re: Need help with 1985 DT 30 Remote control box
    Quote Originally Posted by ecvpaul View Post
    Thanks!
    You need to get a push throttle plate and swap it out inside you NA12 control box. Also in a pinch you can modify the pull plate to make it a push plate by moving the arm to the top hole. You also have to spin the "Drum" item #39 in the diagram 180deg to fit the other slot in the throttle plate for the throttle in neutral lever.
    16. 67220-95600 PUSH PLATE
    17. 67220-95630 PULL PLATE
  1. Remote control help
    By vrdef in forum Johnson Evinrude Outboard Forum
    Last Post: 09-28-2014, 06:25 PM
  2. 703 Remote Control Box
    By moonman60 in forum Yamaha Outboard Forum
    Last Post: 06-02-2012, 08:50 PM
  3. Remote control?
    By auchandler1 in forum Chrysler Force Outboard Forum
    Last Post: 05-18-2012, 07:08 AM
  4. remote control help
    By saront in forum Mercury Mariner Outboard Forum
    Last Post: 08-09-2011, 10:12 AM
  5. WANTED :: 1985 Suzuki DT15 Remote control and cables
    By Steve West in forum Suzuki Outboard Forum
    Last Post: 04-27-2011, 05:36 PM
