The vacuum switch has a rubber diaphragm covering it , about 1-1/2" diameter.----------Why are you looking for it ?
And do you know what the vacuum switch does on that motor ?-----------And are you sure that it is the original block / model year on your motor ?------------Same serial # on the core plug?
You are TOTALLY wrong on that assumption.-------The vacuum switch has to do with the electric shift on that motor !!!
I sometimes ask questions but get no answers to help the poster.--------Perhaps the questions are meaningless or seem like a joke.---Have you found the location where the vacuum switch mounts , yes or no.------Is there a hole open to the crankcase , yes or no.-------Does your motor have the shift diodes , yes or no ?------Have you found the serial # on the block , yes or no ?---The original parts diagram shows the vacuum switch.---------But your motor may have been updated with the diodes.------I am not standing beside YOUR motor so I can not quickly tell you what is going on with it !!!
Kinna confused here in order to be running at high speed the shift lock in the control keeps you from shifting into neutral at high speeds if the pressure switch always provides power to the green wire when the engine is running (has vacuum) how can it shift into forward?Delete.
So how is the wiring from the shift solenoids attached to the vacuum switch? Because it looks like in the wiring diagram it runs directly to the plug. Dan
