Mercury 3.5 06 4 stroke carb rebuild please help!
antx227
Hello ALL!
I'm doing a carb rebuild for my 3.5 (1F03211HK) and I ran into a problem where I have no clue where a piece goes inside the carb. I've never seen it before, but its a small black rubber plug that came out without seeing where it came from. The part number is 8M0060417 and in the diagram you can't see exactly where it goes. Any ideas? I couldn't upload the diagram for some reason, but it is #6 in the diagrams for the rubber piece. Any help would be great thanks!
Did it fall out when you pulled the float bowl?
Yeah when I removed the float bowl it fell from the carb. There is a small hole under the float that looks like it plugs up there, but it doesn't stay on. Never seen this plug before. Any clues? I emailed Mercury and all they sent was this diagram showing the plug.
