Results 1 to 8 of 8
Thread: Prop
  1. #1
    Join Date
    Apr 2017
    Location
    south texas
    Posts
    3
    Default Prop
    I have a 1997 Stratos 21' Center Console bay/tunnel boat with a 2000 175HP evinrude and was trying to decide what Solas prop I should use,the one that was on it was a 14 1/2 x 17 prop(different Brand),just wondering if a 14 1/2x15 would work ,this is all new to me,didn't realize so many things to consider when buying a new prop I do a lot bay fishing,any recommendations would really be appreciated...Thank you
  2. #2
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,744
    Default Re: Prop
    Prop selection has to do with W.O.T. wide open throttle, the 14 1/2x15 might run the rpm up to high and over rev. engine What RPM are you running at full throttle now? For each inch of pitch lower, RPM will increase by theoretically 200 RPM and viceversa. Is your prop stainless or alum.?
  3. #3
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,744
    Default Re: Prop
    Prop selection has to do with W.O.T. wide open throttle, ;the 14 1/2x15 might run the rpm up to high and over rev. engine ;What RPM are you running at full throttle now? For each inch of pitch lower, RPM will increase by theoretically 200 RPM and viceversa. ;Is your prop stainless or alum.? Running the wrong prop. will put an unnecessary load on engine,thus limiting life of your motor!
  4. #4
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,325
    Default Re: Prop
    When you say was on it what happened to the prop? If you need a new one because of damage done get the same pitch and do your tests from there. Size the prop for proper WOT rpm and keep the engine at 3/4 throttle for best fuel economy. If you do your runs at max spark advance your engine will last alot longer. With the engine off shift into forward gear and advance the timing to the point the spark advance stops moving and put a marker on your controls at that point. If you run a engine with too shallow of pitch it is the same as running it low on oil. It takes less fuel to rev faster and it will cook the pistons.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  5. #5
    Join Date
    Apr 2017
    Location
    south texas
    Posts
    3
    Default Re: Prop
    WOT the rpm are 4500...The one it now is stainless,the tip was bent,evidently hit something and wanted to maybe purchase a new one.They charge between 100-200 to fix it.I wanted to get a Solas prop since they are not expensive and have heard good reviews on them,but I couldn't find one 14 1/2x17 SS 4blade,like the one that was on it.Just wanted to get close to that.
  6. #6
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,325
    Default Re: Prop
    You can safely put on a 15 pitch that should bring the WOT around 5000 and it should improve overall performance. It sounds like your a little overpropped anyways. It will improve the hole shot considerably.
  7. #7
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,744
    Default Re: Prop
    I concur on 15"
  8. #8
    Join Date
    Apr 2017
    Location
    south texas
    Posts
    3
    Default Re: Prop
    I agree..thank you again!
Similar Threads
  1. DAMMIT!! I bent my prop shaft and chewed up my prop 1980 Johnson 25 hp J25RCSA
    By Jhanratt in forum Johnson Evinrude Outboard Forum
    Last Post: 09-02-2016, 10:31 PM
  2. Prop burning - Cavitation - Prop Singing on Duo Props
    By Chris Rohde in forum Volvo Penta Gas Engine Forum
    Last Post: 05-30-2015, 06:56 PM
  3. e15rcde prop bushing bad? prop spins on prop shaft while in gear
    By rockfisher805 in forum Johnson Evinrude Outboard Forum
    Last Post: 08-15-2014, 01:09 PM
  4. Prop size question and off shore style prop on a through hub exhaust?
    By H2oallyear in forum Propeller Selection and Replacement
    Last Post: 07-25-2014, 07:07 PM
  5. Trying to determine diameter and pitch of prop on 85HP Johnson from number stamped on prop
    By Bob Padowicz in forum Johnson Evinrude Outboard Archive
    Last Post: 07-29-2006, 11:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
