Re: 1990 evinrude 30 hp 2-stroke "stalling" / "cutting out" problem at higher rpm. please help !!!
hi again...so..i dissassebled the carburator again in order to check for any dirt in it. it is absolutely clean and shiny...gasket is also like new. i also checked the spark plugs. like new as well....and when pulling off the spark plug cap, then of course it continious running... but rougher ...on one cylinder. (same thing on both cylinders...upper and lower one). fuel lines/pipes are also clean. fuel pump is working....but i can't tell if it is pumping the correct amount of fuel to the carb. compression test is something i cant do...dont have the proper tools. after some research in the net, i found out that tha stator could be causing this stalling....i tried to remove the flywheel but again i do not have the right tool to pull it out. anyway...i would bring it to a mechanic (and i have a lot of them in my area) , but i do not trust any of them. i mean i'm sure they are going to try to ripp me off. this s.l.o.w. mode thing is one more thing that i would like to find out how it works. what sets it in function ? the temp sensor? ahhhh... i forgot to tell you that i also installed a new impeller (waterpump) . my engine still stalls at higher rpms ...so i'm still needing some advice/help. it has to be somethin really easy, ...it was running great twice after it started stalling. so when an engine runs fine from time to time...it can't be majorly broken. for example...i can not imagine that the compression is be in one or both the cylinders. on the other hand... i am not a spe******t....some of you guys in here might know better.... ill be very glad to read your possible solutions to the stalling problem.
