Click for Suzuki Manuals, Parts and Model Guides!
Results 1 to 2 of 2
  1. #1
    Default Suzuki DF150 4 Stroke Pee Hole Smoke Puffs..No Water
    2007...ran fine last year. No water stream so I changed the impeller today and have the same problem.. I do see puffs of smoke stream out that appear to be "pushed" by the impeller. I pushed weedwacker line about 10 inches up the pee hole before it stopped.
    Any thoughts much appreciated....Thank you
    Scurvy Dog (aka Tom)
  2. #2
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,984
    Default Re: Suzuki DF150 4 Stroke Pee Hole Smoke Puffs..No Water
    Was water tube in mid unit inspected,upper seal? Was water pump housing sealed properly? Pull thermostat housings off,pull stats out, Water should geyser out when running,telling you pump is working correctly, post back with results, Has a compression test been done on cylinders?
Similar Threads
  1. Puffs of smoke from intake
    By mrmrsdsg in forum Johnson Evinrude Outboard Forum
    Last Post: 10-29-2016, 09:18 AM
  2. Water leak into 2 stroke combustion chamber les or more smoke?
    By Alan Hitch in forum Mercury Mariner Outboard Forum
    Last Post: 12-21-2014, 06:47 AM
  3. 85 Yami pro V 150 4 stroke - no water out of weep hole
    By 1 John Jay in forum Yamaha Outboard Forum
    Last Post: 02-18-2013, 07:31 PM
  4. 1983 mercury 150 studders and puffs smoke
    By tydog in forum Mercury Mariner Outboard Archive
    Last Post: 10-23-2009, 04:58 PM
  5. Suzuki DF150 check engine 42
    By broderaron in forum Suzuki Outboard Forum
    Last Post: 06-24-2009, 06:51 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
