Grounding transfer tank to boat while fueling with gasoline ?
37Dancer
I know the tank is to be bonded to the ground in the boat.. but does a portable tank on a trailer with a 120VAC 3/4hp. centrifugal pump need a ground run to boat?
IT sure would be prudent, especially given the use of an AC powered pump......I'd be inclined to use a similar setup to what an aviation fuel truck uses....
