Results 1 to 3 of 3
  1. #1
    Default Question re bleading injectors
    I have a 40+ year old 6 cylider Sea Lord (marinized BMC) engine that requires occasional bleeding of the injectors. I have noticed that bleeding some injectors makes very little difference in engine RPM while another may almost stall the engine. Is this normal ??? Or is it likely that the injectors need service ??? THANKS in advance. RD
  2. #2
    Default Re: Question re bleading injectors
    Rubber Duck, sounds like you need to have those injectors rebuilt. You may have a few that are not seating properly and in some cases let compression leak back causing air in fuel system.
    Charlie w.
  3. #3
    Quote Originally Posted by CHARLIE W View Post
    Charlie w.
    THANKS Charlie. Sounds like good advice. I was hoping the symptoms might be normal-ish and just need something like "injector cleaner".
Similar Threads
  1. TAMD 41B Injectors
    By frankos in forum Volvo Penta Diesel
    Last Post: 08-04-2010, 02:33 AM
  2. Mag MPI Not firing injectors
    By paston1 in forum Mercruiser Sterndrive Archive
    Last Post: 07-14-2009, 07:34 PM
  3. DF60 Injectors
    By gray in forum Suzuki Outboard Archive
    Last Post: 11-20-2008, 12:48 AM
  4. 140 DF injectors
    By rippin_lips in forum Suzuki Outboard Archive
    Last Post: 08-25-2008, 01:35 PM
  5. KAMD42A Injectors
    By ddesira in forum Volvo Penta Diesel Archive 2004-2009
    Last Post: 04-07-2008, 08:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
