MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 5 of 5
Thread: Oil injection
  1. #1
    Join Date
    Mar 2012
    Location
    La Crosse Va
    Posts
    81
    Question Oil injection
    Just purchased a 1989 Hurricane with a Mercury 150 which is a 1993. it has a oil injection tank on top of the motor and also a couple gallon tank under a compt. previous owner says oil injection works . it also has a 17 gallon fuel tank. Is there any way to check oil injection and should both tanks be filled. I believe the tank on top of the motor leaks when tilted up. Cap is a drain plug. Which way to go. do not want to ruin a good engine.
    1989 Hurricane with a 1993 150 XR6 Mercury
    Serial OD198657
    Retired MCPO USN
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,945
    Default Re: Oil injection
    Cap on the motor tank must be tight and must not leak.------------Motor pumps air into the big tank to keep the small tank full.
  3. #3
    Join Date
    Mar 2012
    Location
    La Crosse Va
    Posts
    81
    Thanks I guess I need to inspect the small tank and find the proper cap. It now has a boat plug in it.
    Serial OD198657
    Retired MCPO USN
  4. #4
    Join Date
    Mar 2012
    Location
    La Crosse Va
    Posts
    81
    after more research I know the previous owner ran off a new 6 gallon tank, premix. I also found out the horn wires are cut. I am going to find the proper cap for the engine oil tank and insure I have no bad or leaking lines, reconnect the horn and see what happens. I may run a tank of premix and see if oil goes to the engine tank. PO had no oil in large tank. I put a gallon in . Is it safe to test or should I use premix and check oil injection?
    Serial OD198657
    Retired MCPO USN
  5. #5
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,838
    PREMIX until you verify that it is working. These systems were prone to fail. The drive gear on the crank strips off its teeth.
    I would suggest that you get the alarm system functioning again.
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
Similar Threads
  1. 2001 Yamaha 225 fuel injection ,bypassing oil injection
    By muddabber56 in forum Yamaha Outboard Forum
    Last Post: 02-18-2014, 12:50 PM
  2. 2001 Yamaha 225 fuel injection ,bypassing oil injection
    Last Post: 01-26-2014, 11:17 AM
  3. oil injection
    By tritonman2001 in forum Mercury Mariner Outboard Forum
    Last Post: 05-31-2010, 08:09 AM
  4. Oil injection
    By jsalduchi in forum Mercury Mariner Outboard Archive
    Last Post: 09-05-2007, 03:59 PM
  5. Oil injection
    By paul Williams in forum Archive 2003-2009
    Last Post: 04-23-2004, 08:36 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
